House/ full mix in monitor mix
Hey Guys,
Im a singer who performs and does his own sound on stage, I’ve got some custom made in ear monitors which cancel all sound out making mixing a nightmare if no one is operating my sound for me.
As there are not other main mix outputs (i.e L&R) where i could get a main mix through my monitors is there a way to programme the mixer so you are getting the same mix as whats going through the speakers?
This would be a huge help and mean i can be much more confident on stage knowing the sound i can hear is the same as the audience.
Thank You
Scott!
you could use a stereo mix like 9-10 and set all the faders to Post fader, and then set each fader to zero db, including your effects returns. MIX 5-6 will be exactly what is going to Mains L/R but allowing you to alter it if you so choose.
Another way is to simply use ther Alt Out and assign the L/R MIX to that output, this will allow a separate volume control for your in ear monitoring.
Thank you so much for such a fast response!
Amazing response, really helped thank you!!
glad to help Scotty!
Dan
