How do I get ch1’s eq like ch2
Hi Everyone,
How do I get ch1 (gray) eq like ch2 (red)? I tried copy and paste but nothing.
Here’s ch2 (red).
Both EQ are flat, so what is the intention? Maybe the low cut filter? But it is off too.
High Pass Filter setting is different, go to the first setting page for each channel and adjust to the same HPF.
I would put it this way:
You probably tried to copy the PEQ with your copy and paste.
The high-pass filter (HPF) is displayed in the PEQ, but it’s actually part of the preamp.
So you should try copying HPF instead of the PEQ.
This might only be possible if it’s enabled (In).
