I’m not seeing the Q setting for the PEQ from the QU-Pad control. Is this restricted to the desk or is there some set-up page required to access this function on the remote pad?
Thanks a lot. Yes, I have that. But I JUST realized how to activate it (you have to double click the little circle to make that control visible). When you first activate the PEQ that Q Width line isn’t visible. Thanks for the tip. It showed me where to look. Much appreciated!
Do you really need to double-click something?
Then things are different with the SQ MixPad.
Here, after selecting a band, its color circle fills up, and at the same time, the Width slider also becomes active.
I put the cursor over the circle and was able to slide up, down and side to side for frequency selection. But the circle stayed clear until I clicked it. When I clicked it, the circle became a solid color and then the width control became visitor. That’s how it’s working on SQ Mix anyway.
Perhaps I’m using the wrong term. I thought QU-Pad was SQ Mix on a tablet. I have my app on my PC. My SQ-6 is across the room. So, I’m using the remote app to control it from my position. Does that clear up my explanation for you?
But you can actually only move a circle if you click and hold the mouse button.
And that also selects the corresponding frequency band.
Just a side note: “QU-Pad” is the name of the app for the QU series - for your SQ, it’s always the same “SQ MixPad”.
