How do you map a Channel to windows 11 default audio WDM input?
Hi, welcome to the forum!
Please give us a bit more information
- Do you have a Qu16/24/32 or a Qu5/6/7? That’s a huge difference…
- PC or Mac?
- What kind of software you use, to recieve audio?
- When you write about ‘a channel’, you mean really one singe channel? Or just a stereo signal? or multiple channels for recording?
For example: I do some small recordings with Samplitude on Windows 11, for this i select the Qu ASIO Driver. On my Qu5 i have to slect ‘Multitrack’ as USB Stream Mode (Setup > Audio > Sync & USB). Under ‘I/O > Outputs > USB’ i select up to 32 signals (Qu5 is set to 48kHz).
I hope this helps a bit - or gives you an idea of what information we need to answer your question.
