hi there, can anybody tell me how to use matrix and
what are the mainthing to use for?
regards … joe
regards … joe
hi,
how to use?
normaly take them as a special output, like recording the sum or feed a delayline/nearfill…whatever
greetings from hamburg
Hi, as selfmade said you can use the matrix to feed delays and front fills etc…
Assign inputs to your L-R buss and assign these(L-R) to matrixes, then in turn patch the matrixes out to you speakers as needed…so you feed the matrixes from the L-R masters…
I always use matrixes to feed my FOH, I run most everything to L-R and these in turn feed the top flown PA w/stereo matrix, the bottom stacked PA also stereo matrix, mono delays, mono center cluster,mono front fills, subs in stereo or mono, mono spots etc…invaluable
You can also assign Groups /Auxes to matrixes…
RayS
R-72/iDR32/iPS10
thanks guys, it opens it a bit more ![]()
greetings from germany … joe
IDR32 / PL6 / Laptop
