How to add compression to reverb
I have read the manual and watch many videos. Can anyone help with how to add compression to reverb? Some videos are showing that as a good idea, but they are on a different digital mixer in the video. I do have the deep edit compressor bundle. Right now I am using the first 3 fx channels only. Thanks!
Not that this quite answers your question, but simply increasing the reverb time will give you something that sounds very similar indeed to compressing the reverb!
Apparently you can patch the returns to physical outputs via IO Patch/Outputs/Rack FX and then cable them to a channel, where you can add compression. There will be latency, but it should be fine for reverb. I haven’t tried this, just looking at SQ MixPad. I’m curious as to what this is supposed to do for you?
