How to add or incorporate reverb from a channel into a Mix
Re QU-24: The horn players in our band want to hear more reverb from their instruments in their dedicated monitor Mix. How do I do this without affecting the reverb levels of the Main LR or the other monitor Mixes?
Hi there. You can do this on the Qu32: (i’m sure it’s the same for the Qu-24)
  1. Select their mix (for example mix 1)
  2. Then select the “layers” button
  3. Then find FX 1 return, FX 2 return, etc. faders
  4. Bring the specific fader up and this will send that effect to mix 1 (their monitor)
Hope that helps.
The Fx should be post fader and go to the layer of their monitors and push the fx return fader to the amount of fx needed
Think of the FX return channels just like any input channel, they have the same
routing and mixing functions available.
Just don’t send an FX return back into itself by bringing up it’s FX send on the FX return.
how mike?
