Some cheap USB-C to A cables are orientation sensitive, so if this happens again with your new cable it may mean you got unlucky with the first cable and lucky with the second. Flipping the USB-C end around 180 degrees will typically fix this - but you’re better off with a decent cable that is wired correctly for auto-sensing.
