How to connect MEU
I have taken the Dante card out of my MEU
I have put the original ME-D dSNAKE/ACE card back in.
I have plugged the ME1 output on the dLive into the ME1 dSnake card.
The link/act lights are flashing on both units.
The dLive is connected into a network switch port and the ME1 network port is connected into the same switch.
I can ping the dLive on 192.168.1.70 and I can ping the ME1 on 192.168.1.40
When I go to the web interface of the MEU, the dLive does not appear in the list of Sources under iDR mixrack selection.
Is a new firmware update required so the MEU recognised the dLive or should the dLive be emulating an iLive for channel sync?
Hi millst,
ME-U / ME-1 automatically extract the channel names from the dLive ‘ME’ port connection. No need to run a second cable to the ME-U Network port.
In the ME-U interface, set all channels to use the ‘Received’ name, and untick the option to source names from iLive.
Hope this helps.
