how can I connect the iPad with the router to work with dlive S7000, where can I go on the mixer to connect it to make work…
nothing to do on the mixer
all configuration depends on the network,
all devices should be in the same subnet
then the software should find the mixer and should connect
Boldman,
as steffen says, you need to set the wireless router to the same ip subnet as the mixrack (192.168.0.70 by default). once the router is setup, plug it into the networking port (not the gigace connection), and if your Ip settings are correct the ipad should be able to connec
