How to send a stereo mix (LR) to separate mono matrices?
I’m using an SQ6 and want to use matrices to send separate feeds to left, right, and subs. With the latest (1.6) firmware, the three matrices can be set to mono, but I have not been able to determine how to, for example, send only the left channel of LR to mono Matrix 1. Is this possible?
No, this is not possible.
Not internally, but in your example you could externally send your left channel of LR via XLR cable to the appropriately patched ‘Ext In’ of your Mono Matrix 1.
Thank you, this may be a handy workaround should I need it.
