How to use CQ-20B as computer audio interface (not only through DAW)
Hello everyone,
Very new to A&H gear, and to digital mixers in general, sorry if that question has already been answered a thousand times before!
So, I get that, when connected via USB to my computer, I can use my CQ-20B to record any input I want through my DAW, and also hear the result, but is there anyway to use as a regular external soundcard on my computer? I mean, when watching a video on YouTube, can the sound be directed to the CQ-20b outputs so that I hear that on my speakers?
When plugged in, I see a couple of outputs shown on Windows, (1-2 to 7-8 if i’m not mistaken), but those don’t seem to do anything when selected, I can’t hear anything from my computer on my speakers. Am I missing something or is this just not something the CQ-20b is supposed to do?
Thank you in advance for any help!
Also, I’d like to use any input on my CQ-20B as input peripheral on windows or any software (Discord, Skype, whatever). Is that possible?
@Dupinguez
There are two stream modes for the USB-B interface on the CQ.
In CONFIG / Digital Audio (Symbols) / USB/SD you can set the stream mode to either Stereo or Multitrack.
It sounds like you currently have this set to Multitrack, so set it to Stereo and you’ll see just the one stereo input and one stereo output device from Windows.
The output from the CQ going to the computer will then be whatever you set for the last channel assignment pair (in the same screen as above, bottom right, labelled ‘Stereo L/R’).
When the CQ is selected as the system output device (for music, browser etc…) the sound from the computer will be sent to the dedicated USB channel on the CQ.
To set up for discord or skype or any other application where you don’t want to send the output from the computer back to the computer (creating a feedback loop or echo for the person at the other end) - set the Stereo L/R output to a stereo linked, pre-fade output instead of it’s default Main LR. This will mean you have total control of what you send to that output separately from what you might want to be hearing in the main mix yourself. Usually referred to as a ‘mix minus’ if you’ve not set up in this way before and want to read up on it.
Cheers,
Thank you for your reply Keith!
I’ll try this as soon as possible.
What is very weird for me right now, is that I see the same list in “Inputs” or “Outputs” on Windows. I’ve had a Motu Track 16 previously, and one great feature it had was that ALL the inputs were listed on Windows to be used on various softwares (very good if you wanna give online piano lessons for example). Any chance that would be possible or added in the future?
I’m in a similar situation, I have the CQ set up to record in Audition and it records just fine but in order to hear the playback I have to go into CONFIG / Digital Audio (Symbols) / USB/SD and set the stream mode to “stereo” (as you suggested here) But this switch then renders all the inputs to a single LR stereo pair. Is there a way to set the interface so I can hear and record without having to change the stream mode?
@KeithJ A&H
How would one go about this specifically on the CQ18T in regards setting the Stereo L/R Output to a Stereo Linked Pre-Fade Output instead of it’s default Main LR?
I did not understand this to my avail.
I’m also trying to use the mixer casually with discord, and the feedback is annoying to say the least.
@WORT-FM
The stereo USB channel either receives from USB channels 1&2 when the USB stream mode is set to stereo, or from higher channel numbers (depending on model) when USB stream mode is set to multitrack.
You can see the source for any channel in the PROCESSING / Input Preamp screen when it’s a Complete Channel - https://www.allen-heath.com/content/uploads/2023/09/CQ_User_Guide_V1_1_0_iss1.pdf#page=79&zoom=auto,-361,588
So to return a stereo feed from a DAW, you should match the output channel number to the USB source channel number displayed.
@Misantropen
The last 4 stereo USB/SD outputs of the CQ-18T are set in the CONFIG / USB/SD/BT / USB/SD screen - https://www.allen-heath.com/content/uploads/2023/09/CQ_User_Guide_V1_1_0_iss1.pdf#page=64&zoom=auto,-361,555 Then the final stereo pair of these is the one used when USB streaming is set to stereo, which by default is Main LR.
Hope this helps!
I own a CQ12T and created a (simplified) schematic of the USB routing to and from a USB-connected computer. The schematic depicts Multitrack mode only. Now that I understand it, the routing is straightforward but it was a little hard to get my head around initially for several reasons. If you’re reading this thread because you can’t figure out the USB routing, don’t feel bad. The mixer UI is generally intuitive, you’re not alone if you find the “Channel Assignment” part of the UI very un-intuitive.
  1. It contains insufficient information to tell you what you're really mapping, or even which direction (input or output). It's obvious once you understand it, but to a new user coming from other mixers, it's not obvious at all. Even the tab label under Configs is not helpful: Other tabs are labeled Config, Inputs and Config, Outputs which set the context for the whole tab. But Channel Assignment settings are on a tab labeled Config, USB/SD and the words input or output don't appear anywhere so there are no clues to what direction you're mapping. A redesign of the visual labeling and layout of Channel Assignment would help a lot.
  2. There's incorrect labeling in the CQ Mixpad app which labels the output USB channel pairs as 17/18, 19/20, and 21/22 when, on a CQ12T, they are really 11/12, 13/14, and 15/16.
  3. In Windows 10, the output devices exposed by the ASIO driver (output from Windows perspective) are labeled CQ 1&2 (ST IN), CQ 5&6 (USB) and CQ 7&8 (BT), but those actually correspond to USB channel pairs 11/12, 13/14, 15/16.
  4. It's also confusing because six of the assignable items are CQ outputs (Main LR, Out1/2, etc.) but one is a CQ input (ST IN). It makes you think you might be mapping PC-channels-to-CQ-Inputs.
Regardless of these issues, it’s a great mixer, and the USB interface is easy to use once you get your head around it.
Perhaps this schematic will be helpful to others (and I sure hope it’s correct!)
I am still super confused about this. Having to flip the input source to USB/SDHC on all 16 channels just to play back a multi-track recording is a royal PITA. And more times than not, when flipping back to Analogue, channels that had Auto Gain enabled before no longer have it enabled. And what about overdubbing? [CQ-20B, MacOS, Reaper]
@TheAngryPenguin
I don’t know your specific scenario, but in my scenario I don’t flip input sources back and forth. I’m using the CQ12T as an input mixer to my DAW running on the computer. I keep the CQ12T in stream mode “Multitrack”. All the channels with physical input jacks are set to Analog inputs and stay that way. Whatever signal comes in via those analog inputs gets sent out to the DAW on the same-numbered USB channel. So if I’m tracking guitar, I set the input channel on the DAW track I’m recording to the channel my guitar is plugged into. Keyboard tracks get input from the keyboard channels, and so on.
For playback from the DAW, I’m mixing in the DAW, not on the CQ12T. The only output back to the CQ12T is a stereo pair containing the output of the DAW’s master bus (the whole stereo mix). The master bus in my DAW mixer sends audio out via the two USB channels that go to the CQ12T’s input channeled labeled “USB”. Those channels are 13 & 14 for the CQ12T, they’re different for the CQ20, maybe 21 & 22 but not sure. The CQ12T input channel labeled “USB” has no analog input jack, it’s dedicated to audio coming in on just those two specific USB input channels.
As for overdubbing, you said Reaper so I assume you’re talking about recording to Reaper not to an SD card in the CQ12T. So overdubbing is just like any other kind of recording, you hit arm the track you want to record, the rest are playing back. The master bus is sending the mixed playback out to the CQ12 over USB channels 13 & 14, to the “USB” input channel on the CQ12T so you can hear them. All other CQ12T channels are set to Analog input and so what you’re playing into the record track is coming from CQ12T over USB. You can monitor the live instrument from the CQ12T (before it goes to the DAW) or out of the DAW, whatever meets your need. Whichever platform you’re monitoring from, you’ll want to turn off monitoring on the other one of course.
Sorry if I’m missing the point of the challenge you’re having, hope that helps though.
I guess I will need to further explore Audio MIDI Setup, as there’s no mechanism in the Audio Device Preferences to tell the DAW to route its stereo output to a specific pair of channels.
I’m a Windows guy and I don’t know MacOS or Reaper well enough to respond precisely, but a couple of things:
  1. In Reaper you will need to have the Audio Device set to the CQ (in your screenshot it is set to a Scarlett audio interface)
  2. The Master track in Reaper needs to be sending its output to the USB channels which the CQ routes to the “USB” input channel on the CQ. (Again, on the CQ12 that’s USB channels 13 & 14. On a CQ20 it may be 21 & 22, I don’t know for sure.) Precisely how to set the Reaper Master to output to those channels on MacOS I also don’t know. On Reaper for Windows I would set the output channels min to 13 and max to 14, which would force the Reaper Master bus to use output channels 13 and 14 as the hardware output. Very different on MacOS I’m sure but the point is: 1) find out which USB channels on the CQ20 are hardwired to the ‘USB’ input channel, then 2) do whatever is required for Reaper Master to send audio out those two channels.
(screenshot borrowed for reference…) – The forum wouldn’t let me reply from where I was at on that day – it thought I was trying to spam the board.
Anyway, thank you for pointing me in the right direction.
Salve a tutti, ho un CQ20B e utilizzo Audition come DAW, avendo una traccia audio solo strumentale voglio registrare solo il canale microfonico come si fa? Qualcuno mi può aiutare?
I have added all stereo pairs to the master out, and I am still unable to get any DAW playback through my CQ-20B. According to Channel Assignment, 23/24 is set as Main L/R (Stereo L/R). What am I missing?
Got it! It’s 21/22. Not sure why it didn’t work at first.
Ok. I figured this out, but it isn’t easy. First, make sure you download the CQ USB Audio Driver from this page - https://www.allen-heath.com/hardware/cq/cq-12t/resources/. If you have Reaper open restart it after doing this.
In Reaper, go to Preferences/Audio Devices. Choose Audio System ASIO. CQ ASIO Driver should be in the list of ASIO Drivers. Set it up so both input and output have the full range of available channels. (16 in this case).
Your Master Out is the hard thing to set. You have to go to the routing menu on the Master slider. You will need to add a HARDWARE OUT. In my case, I used input 10 because there is no way I will ever be simultaneously recording 9 audio sources in my basement. Once you do that, and so long as Input 10 is set to USB/Bluetooth and sends to main LR, you will hear whatever goes through the master through the headphone jack (which also needs to be set up to be receiving from the main LR).
Is it possibe to update the firmware and use the main l/r as the output for the DAW’s playback that would be great. Even if I assign the 23/24 as main l/r there’s still no output. Hoping for it to come. Thanks.
Hi there to all,
Happy new year!
This is my 1st post at the A&H community!
I have an CQ20B using it for home studio purposes running both mac and windows.
I was wondering…if i want to record simultaneously all inputs (1-16) and at the same time have a playback (backing) stereo track from a DAW, is there something that i should do routing wise?
'Cause i just tried and it seemed that i had to “sacrifice” 2 inputs (1 & 2, Reaper).
I’m using Reaper (Mac - Win), ProTools (Mac) and sometimes Logic Pro
Hello. My question is, can I use more than one stereo pair of outputs from my CQ20B in Pro Tools? That is, use one stereo pair as the main output and other outputs as sends from the DAW. Thanks.
