How to use Custom Layer QU16
Hello,
I have a question about my QU16. I loaded the new firmware V1.10 on my QU16. However, I experience trouble in the programming of the custom layer. I tried a lot of things, but nothing seems to work.
Has anyone already done this? Can you please tell me how to program the custom layer?
Thanks in advance for your help!
Midbrain
Note that a new forum for QU-16 was created recentl.
rob at lynxaudioservices dot com
Dear Rob,
Wear can I find it QU16 forum?
Thanks for your answer.
midbrain
I had this problem too. Don’t feel too bad.
Press the Setup Button
Select the Custom Layer Tab
Touch the X under CH1
Rotate The Encoder clockwise to select channel you want to control from that position.
You can choose Inputs 1-16, ST1-ST3, FX1-FX4 Return, FX1-FX2 Send, Mix1-Mix10 and LR
The Fn button below is used to add the next custom channel.
mamerica
Mpls, MN USA
Hello Mamerica,
thanks for the explanation, it works perfectly [:smiley: ]
many thanks
Midbrain
