How do I reset admin password? ILIVE T112
Fernando Lopes
Fernando Lopes
I do believe the only way is to reset the whole console. I’m sure someone will correct me if I’m wrong.
Straight from p. 75 of the OM.
Note: Only set passwords if you really need to.
Make sure you keep a log of all passwords
allocated. Clearing passwords required resetting
internal jumpers and clearing the memories.
Hi Fernando
To reset passwords on your iLive system turn off the system move jumper 8 in iDR10 - iDR0 or dip switch 4 on T-Series mixracks to the ON position. Then power On the system wait for system to connect then power the system off. Set the jumper or dip switch back to the OFF position. Your passwords will now have been reset
Note:
User Names, User Permissions and user default scene at startup will all be reset to factory default settings.
Regards
Sam A&H
quote:
Note:
Regards
Sam A&H
I am not going to question your knowledge, but I had documentation telling me it was jumper 7 (for the 144 and IDR). I am now wondering if my documentation is wrong, this was changed with a firmware update, or maybe it was a typo in your post. Can you set me straight?
Info from:
iLive Service Hard Reset and Memory Location Issue 2 CP 01-06-07 page 3
Hi Kris
You have a very old version of the documentation. Please contact your local distributor for a copy of the latest version.
J8 on the mixrack will reset User profiles:
• User names
• User passwords
• User permissions
• User default power-up scene
J7 on the mixrack will also reset User profiles but also:
• Input setup – mono and stereo channel settings
• Mix configuration
• Buss configuration
• Mixrack IP address
Regards
Sam A&H
Stealth,
Thanks for the clarification and I will make a note of it.
Kris
