HPF and inserts
It looks like since v1.5.11 HPF does not work when insert is enabled on channel on our SQ5. As soon as we disable insert filter works correctly.
Perhaps there is a workaround to get them both work together?
@Gunars
We’ve not been able to reproduce that here - could you please contact us by submitting a ticket via support.allen-heath.com so we can look into this with you?
I just did some additional testing and now it appears to work correctly. Yesterday on the other hand I moved HPF all the way right and left and switched it completely off and on again but nothing helped.
I updated SQ software on Friday. Perhaps something was just stuck and some scene changes or something else undid the issue. I will do some more tests and report back in a week or so.
