I cant connect airport extreme and qu16
Can somebody sent me step by step procedure for connection qu16 and airport extreme by airport utility program
Without one here to go through, I can’t remember the exact steps. However, the bit that had me stumped for a long time was that you have to go to on your iOS device and scroll down to find the Airport, before you can use the utility program. After that, everything was pretty simple IIRC.
If that’s not your sticking point, I can probably find time this evening to have a look.
This can also be found in post #40308 by mamerica.
That’s a good guide to using a computer & cable to do it, though it’s also possible to just use your iPad/iPhone and WiFi.
It should be a sticky in the Topic block.
