i live t80- record surface input
Hello!,
im new to hte forum and im looking for help with:
I have a the iLive-T80 and iDR-48. i can record all 48 channels and play back.
The t80 has 64 channels, and mine has the surface inputs (stereo) assigned to channels,
59/60, 61/62, 63/64. i can connect any device to those channels and it will reproduce, and here comes the question:
Is it possible to also record that channel?
channel’s source select is :
Device : ilive surface slot A Socket 3/4
Output for that channels says not patched
is it possible ?
thanks in advance.
YES If you click on the “not patched” or the arrow next to it you will get the menu. send it to direct out!!! or port b ace or whatever you use for recording…
Rays
Like Ray says, but you have to be on the ‘outputs’ config page 1st.
Unless you are using Editor on-line, then you want so select the I/O config tab from the left edge options.
