Hi, one of my mix-racks (iDR64) has developed an issue with powering up. Upon applying power it makes all sorts of random clicking noises internally. If you cycle the power a few times it will power up and operate correctly. One time it appeared to of powered up correctly but all the meters were redlining on the surface and the system is unusable, a power cycle resolved this. Has anyone else had a similar issue? I’ve been advised it’s most likely a PSU issue, I don’t have the IPS10 and they are sadly now discontinued but even if I could find one, the price seems to be around £1500.00 !
Ciao,
Credo di avere un problema simile al tuo sull’IDR64 modulare.
Come hai risolto il problema?
