I need some assistance please… switched ON this morning our iLive Digital Mixer 144, the Surface is ON but the touch screen is blank. Nothing appearing; meaning i can’t see the system loading its O.S . The screen is all White. I need to use it later today and likewise tomorrow !!
I had this happen to me immediately following my recent processor upgrade. I was told to connect an en external monitor to the VGA port on the back and it started up just fine. my monitor doesn’t even have to be turned on and the touchscreen works as it should, however if the VGA cable is disconnected then I get the all white screen. just make sure the monitor is connected before you start the surface.
@ jr.riechers - I tried that but it didn’t work for me… I tried resetting the network settings by using a small pointed object to insert into the reset network settings port This did not repair the problem either. I guess it is most likely an internal issue and will have to be sent in for repair.
I had the same blank screen on my T112 at startup yesterday. I had this a few times some time ago but after a switch off/on the surface worked again. i thought it was cold wether.
But yesterday the blank screen stayed after several restarts. in the end i switched the on button 10 times very fast on/off an bingo it booted normal an worked through the night.
At the end of the night i shut down the T112 in the normal way ( as i always do) and again it started up with a blank screen.
@ SNOEI : did just changing the battery solved the problem or was the bootrom defect?
thanks, i shall contact support to see what should be done.
My T112 is ± 3 years new. I looked it up an a cmos battery should last 2 to 10 years depending on environment/battery type/current draw from the board and how long the board is turned off. this could be right as my T112 isn’t working all the time and 3 years could be.
I took out the SBC PC and the backup battery was dead: 0,8v instead of 3,2V. I replaced the battery and the SBC came back to live but the touch screen still was white although the external screen now worked as expected.I had to make some changes in the BIOS ( because when the backup battery is dead or removed everything is reset to default)
i had to set the resolution to 800x600 and the screen to LCD/CRT.after saving and restart now the touch screen is working again.
I still have to re-enter some other settings in the bIOS concerning processor speed and power management: i don’t want the pc go to sleep in the middle off a show. I asked A&H but still waiting for the settings. I tried looking in my R72 bios settings but unfortunately it is PW protected by A&H.
What worries me is the fact that after 3 years the battery had to be replaced( meaning de-solder it from the pc board).
If someone else can provide the right BIOS settings that would be great because i need the surface Saturday.
I checked the changes I made on the default bios settings:
1: Display Device: CRT + LCD
2: Panel Type: 800x600 1Ch LVDS
And like Lieven described, changing these settings should be done with an external screen, because the touchscreen isn’t working before the setting changes.
