iLive and iPhone? A marriage made in heaven?
Is there any plans for an iLive app on the iPhone?
I.E a scaled down version of the editor, would be useful for personal monitor setups or just tweaking when walking the room…is this a possibility?
Does anyone think it could even work?
Let me know your thoughts
Tom Edwards
bigblueboxuk.com
You can use a VNC client on your iPhone. That will give you the possibility to control the editor on your mac or pc. It will give a small delay but ik works fine to me
Je moet een gegeven kabel niet in de plug kijken!
My guess is you’d be more likely to see it on an Android phone first. The editor is written in Java, and that’s what Android uses for apps. So it would be a much easier port. And in the next year or so there will be a lot of different Android phones on the market.
David Schmoldt
Hello All
For those not in the loop VNC is a way of virtual networking.
It allows you to run Editor on a laptop and then by using a VNC server forward (send) the screen data to your iPhone.
The iPhone then displays an exact copy of your laptop screen and sends back keyboard and mouse information to your laptop, by using a VNC Client.
We’ve tested a laptop running Editor with Real VNC Server
with an iPhone 3GS with Jaadu VNC Client- available from AppStore.
https://www.jaaduvnc.com/
Which works quite well, the click and drag take a bit of getting use to, but for remote control from an iPhone its reasonably usable.
We’re still looking into a native iPhone app, but no promises as yet, so in the mean time this might be a good solution for all you tech enthusiasts !
Andy
A&H
Hey - I got an iPod Touch for XMas (Lucky Me) and this is SOOOO COOOL!!!
I was thinking of getting a tablet PC so I could remote EQ speakers from anywhere wirelessly but with this set up I can pull the iPod Touch out of my pocket, run jaadu VNC and have my laptop screen and control of it in the palm of my hand in a matter of seconds! You can navigate with precision in mouse mode, select an output EQ window, zoom in (simple three finger tap)then change to touch screen mode and EQ away on the faders.
Imgur
If you have an iPod Touch or iPhone and a wireless router this is so easy to set up and use. Actually if the router is connected to the internet then you can remote control any software on the laptop/desktop from anywhere with internet wi-fi access. Brilliant!!!
Richard
IDR48/T112
Worth noting that Apple’s soon-to-be-announced Tablet will be running a version of the iPhone OS, which may be more reason to develop a native application for that platform. Whether it will support Java is still unknown (iPhone does not).
edit: it does not support Java.
Just bumping this in response to the announcement of the iPad. It seems to me the time has come for a native app.
Stephen Tyler
Coordinator of Technical Operations
ACM@UCO
www.acm-uco.com
iLive T-112/iDR-32
I have a 22-inch touch screen running under Windows 7. I tried running the editor software … mo way would I want to use that in touch-only mode. A big fat finger doesn’t have nearly the precision of a mouse pointer and mouse.
David Schmoldt
Which is why a new UI from scratch should be developed for a tablet. You can’t just shoe-horn an existing GUI into a form factor like the iPad or iPhone, it just doesn’t work.
Hello All
Not promising anything yet, but what sort of features would people want from an iPhone app ?
Any discussion or suggestions would help us in the design of future software, so get involved !
Cheers
Andy
A&H
Small child with good eyesight small fingers and an advanced brain to work the blessed thing is what I would need Andy[:smile: ]
i got a msi all in one touch,with the desktop magnifier (win 7) its cool the only thing i miss is double touch (the screen does support it)
of course the magnifier is a workaround- it would be great to have resizable channels-at least in the custom strip, i miss as well mousewheel ability
on faders- too it would be cool to have “numerical” input on everything “that has numbers”
ps: what the heck is finding nemo colour sheme in the editor jar???
sounds like bloody mickymouse[:wink: ] (john hembrow alvin lees manager)
cheers
dave
allen&heath iLive-144 /idr 10 /
Mainly the ability to easily and quickly access mix output GEQ,PEQ, Level and delay settings - very useful for setting up speaker zones. For the GEQ how about say eight touch faders (landscape) with a bottom freq scroll bar (Swipe left/right)and bank L/R buttons, with numerical level values above each fader (so your fat finger doesn’t obscure your view) and along the top display the current selected mix (Text)inside a horizontal master level fader. Also next and previous mix buttons (or a drop down menu?)to quickly select another mix with the GEQ window staying active and updating. Level faders would likely need a slow ramp up time so you don’t accidently bump something to full just by tapping in the wrong place! Or perhaps master levels can only be turned up with say a two finger or combination touch?
Perhaps overlay the spectrum analyser on the GEQ? That would be something special!(Like Contour/smaart)
Another suggestion would be to be able to put (and lock) a single monitor mix send on the iphone/touch . Then each musician could have their own iphone/Touch for their monitor send. Kinda like a wireless Aviom personal monitor. As you can connect multiple editor sessions this should be possible?
Richard
IDR48/T112
forget the iphone, just worry about the iPad!!!
picture this…omg there are two (maybe even 3) frequencies feeding back right now…here, let me grab all three! and bring them down 3db…
I think the ipad would be much better for this. If the app would run on both it would be great. Obviously it would need to be limited, things like channel mute and fader control would be nice very simple and limited. Then maybe punch a button to bring up an eq screen or limited channel strip. Forward and back arrows would be nice kind of like a browser so you could go back and forth from one screen to the next. have the fader view assignable to any channel aux etc even mains. Just in case…Will need to come up with an easy way to select what you want to see though since the screen real estate is limited.
I’m really liking the SuperStrip in Vers 1.6 Much better screen sizing for the ipod touch when using VNC. Not sure if this has been intentional but excelent work A&H! The larger GEQ window is also much better when in touch screen mode. Still would like to see previous/next channel select buttons in the same window though!
Cheers
Richard
IDR48/T112
As a stepping stone for the iPhone app, what about as a PL type device?
Support for the two finger zoom that translates into finer resolution on the parameter you are changing should help with the ‘fat finger’ syndrome.
I am not so concerned with catching 3 frequencies at once as I don’t think I could pick them all simultaneously that fast.
just for my information…does someone have running an application on the iphone/ipad, controlling the mixrack?
greetings from hamburg
I would sooner A&H resources be focussed on developing the existing software rather than creating a whole new branch for a smaller device.
The editor will run natively on a Mac or a PC and even in Linux with some coaxing. How many other mixer editors do that?
I think the problem is not that the I-Live editor doesn’t support the IPad, the problem is the IPad doesn’t support Java. We should be lobbying Apple to support Java rather than making companies like A&H bow down to the latest trends from Apple. Vote with your feet!! I certainly won’t be wasting my money on an IPad until it provides compatibility with the applications I use, not the other way around.
The IPad is cool, but whats the bet within 6 months there will be a PC or linux based clone that DOES suppor Java, use one of those instead until Apple sorts itself out.
end of rant.
Cheers
Toby
www.np.co.nz
Oh, but just as a followup to that.
I think it would be way cool if A&H released an API or the specs on the editor comms protocol so that people could develop their own interfaces.
How much value does that add to A&H if people start doing development for them. Same with the effects, imagine if people could build and sell their own effects plugins!!! It creates a whole after market which will make the hardware platform last much longer.
If A&H releases the comms protocol then if I wanted an I-Phone app i could write it myself to do exactly what I wanted it to do and then share it amongst all the users (or even sell it if it was that good).
Just a thought.
Cheers
Toby
