I have several ilives … 2xr72 and 2xidr32 racks! they don’t see much use anymore but still at 10 years old I’ve seen posts where the screen had issues related to the bios battery or similar, I want to put the boards out on a series of “zoom” style shows next week, how long should i expect them to function ok ? is it based on years “age” or running time average or other??..
I would open them up and replace them if they haven’t been replaced yet. My iLives are also 10 years old and I needed to replace the button batteries for the bios in those. Note they are hard soldered to the main board and once re[laced there is a procedure to boot up again! Something to do with the screen correct resolution. Info should be available on this from your supplier or A&H support.
On my T112 I took an extra step and put a remote battery holder so that replacement if needed again can be done simply.
Those batteries should be replaced every 5 years to be safe, although I’ve had them last for over 10.
And Stix: thanks for posting that picture: the battery looks to be easily accessible by removing the side panel. The picture is reversed though; the battery is on the right-hand side of the board by the talkback mic input/headphone volume control.
That’s easier than getting to the battery in a GLD!
The picture isn’t reversed. As I mentioned I put in a custom battery holder to make any future replacement easier behind the right mixer side panel. The original factory position of the battery was on the right side of the board beside it.
Hey Stix:
So sorry; you’re absolutely right! I thought the mixer was sitting on its back, but the channel LED’s are below the control section, not above. It’s been so long since I’ve seen my iLives I’m forgetting what they look like.
