I’m setting up a large system in a fixed install and have a question concerning Dante.
The system is T112, IDR64 (master) and IDR16 (slave) ME-U.
The IDR 16 and the ME-U are fitted with Dante…
Can I choose which channels are sent to Dante like any 30 channels from the Master and any 10 from the slave? Where do I set this?
Thanks for any suggestion
Never done exactly this way of routing, but did something like that to record via Dante from dual rack setup. First you send what you need from master rack over ACE to slave rack, this is done via output patch window. After switch output window to show slave rack- send appropriate ACE channels to any Dante channels and also send the necessary signals from slave rack to some Dante channels. When it’s done, do the patch via Dante controller between M-Dante module and ME-U. Quite simple, I’d say.
