iLive Editor - Pull up saved shows while in a mix
Not sure if this is already possible. If so, I haven’t seen it documented. I’d like to be able to be in a live mixing situation and use the iLive editor software to pull up a show file without actually loading it into the iLive.
Here is an example. Someone who I did not expect to speak is suddenly at the mic speaking. I have PEQ settings for their voice saved in another show file, and it isn’t in the library yet due to a fork/branch. I would like to quickly use the iLive Editor to open that show file and display the PEQ settings so I can quickly dial them in by hand. Even better would be the ability to push those settings in real-time to the desired input channel, overwriting the PEQ that is in the currently running show.
Kind regards,
Mark
