ilive editor question
First apologize me for my very bad english.
Si quelqu’un parle francais :wink:
Ok, I want buy idr 48 mixrack without surface and use computer for mix. For this time I downloaded editor and use this off-line, just for see what is the best way for working.
I not understand how to create mute group or dca :frowning_face:
Usually i’m working with yamaha digital desk and i use studio manager. I love the “main view” of selected channel. The same view do not exist on ilive editor?
Another question, how to save my configuration? For exemple i build fx rack but if i close/open editor the fx rack is empty.
Regard’s
Alain
Hi Alain,
To create a DCA group, you need to press the mix button at the bottom of the DCA channel strip you wish to use, then press the on/off buttons at the top of the channel strips you’d like to be part of this group. For Mute Groups the procedure is the same, but you need to turn a DCA into a mute group by right clicking on the DCA channel and selecting the mute group menu item.
To save your configuration you will need to archive a show from the show manager, and then restore it when you open editor in the future.
Hope that helps?
Colin A&H
Thank’s a lot Colin.
The right click doesn’t work, but in dca channels menu options i found “show mute groupe buttons”
After i select this options i think if i press “mg” buttons in dca channel strip and follow your instructions i’m create a mute group, correct?
I still have some work with ilive editor, to find how to make a virtual sound check for example, then I risk to return often on the forum.
Have a nice day,
Alain
Yep this is correct :smile: .
Good luck with your virtual soundcheck!
Colin A&H
quote:
I hope is not an impossible mission ?!
But for this time i not found how to… Just patch b port (madi) 1 to 48 in “input-direct out” for recording and press “virtual sound check” button on ilive editor for playback?[:p]
Oups, i don’t see this button[:frowning_face: ]
If anybody know the best way for create and use this function…
I was going to forget, i search how to view and use delay input channel.
Alain
