ilive editor
Hey Guys,
does anybody have an idea why I always get the same error code on windows 7 when I start my ilive editor. It says: please open the application with the script provided, or with the following command line arguments: java -Xms256m -Xmx512m -jar…
Somebody told me to install java 32bit and that is what I did, but I have the same **** anyway…
Thx for reply
Hi Michel
This is a known issue with old downloads of 1.54 Editor. We have now made some changes to the installer that fixes this problem, please go to the iLive website and re-download v1.54 this should fix your problem.
Hope this helps
All the best
Sam A&H
Thanks for that Sam,
so I guess the next problem I have is the old version 1.43 that I have running on my surface and my mixrack…
I think its time to update my firmware, but first I check the newer 1.54 version. If this is running, I can be sure that my problem is fixed.
I’m gonna keep you informed.
Thank you
Michel
Hi Sam,
all I can say is thank you, thank you and thank you.
I installed the recommended, newer 1.54v and now everything is fine.
Thank you again
Michel
VX Concept
Hi Michel
Glad to hear you are back up and running :smiley:
Best regards
Sam A&H
