iLive Scribble Strip Repair
Hey Everyone, in case you have pixels going bad on the scribble strips, you can easily repair the screens with a plastic tool and heat gun. Use 250c temp and heat the ribbon cable for maybe 10-15 seconds before using the plastic tool to push down the ribbon cable. to access the cable, you’ll need to pull the screens off of the color panel and then pull “down” the screens to reveal the ribbon cable connection. Sometimes they need longer heat, or multiple attempts. NOTE: to test screens surface MUST reboot each test to assign the screen chips.
So are you essentially reflowing the soldered connection of the ribbon cable? Whats actually being done with the plastic tool? Im gonna give it a try this week. All of my scribble strips have only a few working pixels left on there.
