iLive T series road cases
I’m interested to see some of the cases that people have had made for the T112 or T80. I’m getting ready to order one and I want steal other peoples good ideas :smiley:
Hi Ryan,
Mines a simple 2piece design, it has 100mm gap at the back, i didnt opt for a dogbox as i figured it wouldnt be needed.
10 handles, tourlabel and dish.
https://www.spider-engineering.co.uk/music/listproducts.asp?modelid=4924
In fact that is my desk in the pictures, it was the first case they built for this desk.
Cheers
graham
I would like to show some pictures but does anybody know how to put them on the forum ? bmp ? , Jpeg ? resolution ?
There is an icon to insert a picture but i can not paste one.
kind regards
I found out how to post pictures
Lieven
Thats the rack IDR48, UPS with 3 subsnakes 16ch and monitorsplit 48ch
and drum with hybrid cable 2 cat5,1audio,power
Hey Lieven
Just looking at the photo’s of your Mixrack/ raodcase set up. Looks impressive! What is the multi cable you use for the iLive - with power, 2 x Cat5, 1 x Audio? I’ve been looking for something like that. I have found the Sommer Cable SC-MonoCat Power212 ( https://www.sommercable.com/2__default/index.html ) which looks good but expensive. Have you had any issues with power and data down the same cable? Also have you terminated this to a plug socket at the rack end that accepts the different cable types including mains power or does it split out to tails?
Cheers
Richard Howey NZ
IDR48 /T112
Stix,
I use the pinanson ( spain) cable. it is a power(3*1.5mm2),1 audio/dmx,2 UTPCAT5.(60m)
But i am not fully satisfied.The network status on the surface indicates sometimes that there are some errors in the utp connection ( orange or sometimes red ). This happens only when people walk over the cable. When the cable is up in the air or out of the way all is fine.
Although I never lost connection or had zero glitches i will buy a second separate utp cable for very critical shows. I think neutrik . Watch out, there is a new document in the knowledge base about the type off utp that will work. Belden 1305A was in the previous supported cable but now it is ruled out as sufficient.(Cat5 cable for ACE: https://allen-heath.helpserve.com/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=198&nav=0,5 )
I put a multi pin on the cable with the connections available on a 19inch panel ( see photo )
kind regards
Lieven
T112/IDR48
Disclaimer: I disclaim everything. The contents of this message might be totally inaccurate, inappropriate, misguided, or otherwise perverse - except for my name (hopefully I got that right).
quote:
Originally posted by Lieven Dewispelaere
Stix,
But i am not fully satisfied…
…I put a multi pin on the cable with the connections available on a 19inch panel ( see photo )
kind regards
Lieven
Hi Lieven,
That multipin connection might cause some trouble. The twisted pair in the UTP cable does have to remain twisted all the time. Even 2cm of untwisting may endanger the datatransfer quality. Note that the cables will not be twisted in the connectors, hence the reason why network connectors are always pretty short. Add to this people walking on the cable and you might end up with the problems you describe.
Wouter
Wouter,
I could bypass the multi connector and split the cable into power and the two UTP and XLR. With separate connectors. that should solve the twisting. I 'll give it a try and let you guys know.
Kind regards
Lieven
T112/IDR48
Here is our case if any one is interested. It was built by olympic Case and it fits like a glove. I am very happy with this case:
Small dog house for storing a few cables and things
