iLive T-Systems with PL-6 Controller- NO GOOD
I’ve been attempting to use a PL-6 controller with an iDR48-T112 combo for quite sometime now, just to add some quicker access to some important faders on the console. The problem is that the PL-6 controller loses connection to the mix-rack regularly (every 5-10 seconds) then reconnects. This make for quite the headache when try to program, or use at all.
1.) I first thought that it could be a cat5 cable issue. Changed the cable- no dice.
2.) Next I tried ruling out the length of the Cat5 cable being a problem; Tried 4 lengths,
300’, 100’, 50’, 6’. Both shielded and un-shielded- no dice.
3.) Next I tried to see if I had a bad PL-6, luckily we are a production/install firm and
have access to extra of everything A&H :smiley: - Tried 3 different PL-6 controllers- no
dice.
4.) Next we tried ruling out the possibility of a firmware bug. Tried on 1.83 & 1.9- Same
issues- no dice.
5.) Next we tried swapping mix racks- Tried 3 different iDR48’s- Same issues- no dice.
6.) Next we tried swapping out for a different model of mix racks- Tried an iDR16-
This problem does not occur with a PL-10. Anyone else havin this issue? Thanks.
John
System Integrator
Entertainment Arts Inc.
I’d go with a couple of MIDI faders instead. Easy to program with the learn function.
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
We use a PL-6 with no issues at all. Our pl-6 controls several faders, mutes and even some scene recalls for our iDR16
112T/IDR48/IDR16
quote:
Wouter
I agree. That is the next step. Thanks!
John
System Integrator
Hey Kent
What type of cat5 cables are you using? I wonder if it requires shielded.
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
I will need to check but, if I recall it is a standard Cat5 cable. The length is less than 10 feet. I go back in Friday and will check into which cable we are using. We made the cable from a roll of cat 5 we had for running from the mix rack to a router at FOH.
quote:
Originally posted by gilparente
Hey Kent
Gil Parente
iLive 176, T112
Multiple iPads
Dante
Etc…
112T/IDR48/IDR16
Hi John,
Do you know what colour the top LED goes on the PL device when the problem occurs? That might help us understand what’s going wrong.
Does the problem happen with any show loaded? Have you tried loading one of the template shows just in case?
If that doesn’t work, perhaps it’s worth contacting A&H Technical Support (https://www.allen-heath.com/uk/support/pages/support.aspx), as they may be able to help.
Cheers,
Andy
A&H
quote:
Hey Kent
Gil Parente
iLive 176, T112
Multiple iPads
Dante
Etc…
112T/IDR48/IDR16
It is a cat5 cable solid core. It didn’t look shielded. I tried to read the numbers off the cable but I forgot my glasses >.<
112T/IDR48/IDR16
According to the pl-6 user guide AP5197 page 2, section “Grounding” The exposed metal panels are grounded through the PL-Anet cable shield. It’s also reads: Use flame retardent CAT5 STP (shielded twisted pair) RJ45 cables.
Well there I sounded like a school teacher, but we don’t have any problems with our pl-6, but we always use a shielded cable.
https://www.allen-heath.com/UK/Products/Pages/ProductDetails.aspx?filename=DocumentMaster/uk/pl-6_ug_ap5197_4.pdf
MobileMusic
iDR-48, iDR-16, xDR-16 T112, T80
PL-6, MixPad, Tweek, OneMix
quote:
Originally posted by AndyH
Hi John,
Cheers,
Andy
A&H
Andy,
The LED color turns red very quickly, then back to green. It’s intermittent. I wish I could use shielded Cat5. But the install distance is about 150’-175’ of Cat5E. I will try a short piece of shielded cat5 close to the mix-rack, but it won’t solve my issues. I did contact A&H tech support here in the U.S with American Music and Sound, but no success. Thanks.
John
System Integrator
John, you could have a bad PL6 have you tried a different one? and see if that fixes it?
Or the PSU in the PL-anet network could be funky. That is also 20V over Cat 5 and RS485 on that leg.
I always use CATE 5E sheided cable, but again, sounds like it might be a hardware issue.
Ive got 2 PL6’s in my church on an iDR64 and it runs fine all day long… we use it on a regular basis.
Vice President of Sales
Allen & Heath USA
Well now I got problems with my PL-6.
The RJ-45 input connector seems to have some bended pins.
I bought some new and I’ll think I’m going to change them this weekend.
Christian
MobileMusic
iDR-48, iDR-16, xDR-16, T112, T80
Seems as Shielded Cable for PL6 is required. Thinking a little about how those faders work, it makes sense.
The PL10 only uses encoders, so STP is not really required.
Gil Parente
iLive 176, T112
Multiple iPads
Dante
Etc…
By the way, do you have used the terminator?
