We are having the “white screen” issue when trying to turn on power to the iLive. I see that we should try replacing the cmos battery.
QUESTION: How do we access/find the battery?
Located and replaced the battery. Still boots to white screen. Ideas?
How do I reboot the screen if it is all white? I can’t see where to touch.
When you have the white screen you have to first replace the backup battery on the mainboard who is located under the touchscreen.
unfortunately this is soldered to the mainboard. I removed it and soldered two leads with a battery holder for future easy replacement. i think it is a CR2032 but it is indicated on the old battery.
Then you have to connect a keyboard and monitor screen to the usb/vga-output.
When you power on the surface you have to enter the BIOS for the mainboard ( press F2 or F10 or something: it is indicated on the startupscreen)
go into the video screen settings and change the resolution to 800*640 (SVGA?) save and restart. touchscreen should be working normal.
Lieven
Same problem here…
Questions:
When i enter the bios set.up it requires a password, what is the default password to enter bios set.up
If you remove the CMOS battery (which requires at least de-soldering it, but might be easier to just cut or repeatedly bend the leads to break them), I suspect the need for a password will be cleared so you won’t need it.
I have changed the cmos battery and i did try to plug in keyboard and monitor,it does not detect the two of the device but the motherboard is just working fine so what is the problem?
Admin removed this post as this info is sensitive and should not be in the public domain.
Sorry. While we appreciate your contributions to this topic, we’d prefer not to have customers potentially tampering with the bios on our products.
Hello, is their anybody out there?
Hello Jörg,
Yes, it is advisable to remove the whole board. In my case, the board (Fujitsu) was fixed with TX10 screws, but the CR2032 was not soldered but socketed. However, there are different versions of the board. Are you from Germany?
Many greetings
Bear
Hello
And thx. Yes from germany. We just had changed the bios battery but no result.
Lg Jörg
I’ve had some luck with my T112 having previously had the white screen error.
I found online the manual for my SBC, the fujitsu one, & noticed the front panel conector wasn’t used in the ilive. I took a chance & connected a PC power switch to the front panel header & miraculously the SBC beeped into life! Hastily I connected a keyboard & monitor & noticed that the BIOS had reverted to it’s default state, so I replaced the battery, set the bios date & time, set the boot device to the CF card & after a couple of reboots & a couple of bios changes everything is now working as normal.
Where did you connect the PC power switch to? I can’t see any indicators on the Fujitsu as to where/how to connect a PC power switch. Please advise if you can!
I can revive a dead SBC
and running normally
Contact me
WhatsApp +6281229445410
I have an Allen and Heath ILive T112. I have the white screen. I found your article that has the formula to make this console work. Can you help me?
