iLive Tweak falls
Mixed a show yesterday night with iPhone & Tweak. Made life easy as we had no space for FOH. We used only monitor mixer (T-80) and I connected with my iPhone. Everything else was fine, but Tweak falled several times when trying to access channels. Several means 30-40 times. Waiting for bug fix :wink:
Pitk.
Jukka “Pitkä” Kurkela
Äänimaisema Oy, Finland
iLiveT80 / iDr32
Have you already considered a bad wifi connection?
idr32
Editor only (3 times)
Korg nano
Dante
quote:
I think that’s not the problem. Tweak has fallen several times in demo mode and yesterday it fell several times even I stood one meter away from WLAN router.
Edit: iPhone 4 with latest OS.
iLiveT80 / iDr32
When you say failing do you mean the app crashes, or simply disconnects? If it’s disconnecting constantly you’ve probably got an IP conflict on your system. Check that your router & all the associated parts of your system are addressed correctly as per the suggestions on the reference guide (available via the Allen & Heath site downloads page),
Alternately you may have a dodgy download (particularly if, as suggested, it’s kicking you off without even connecting to a network) - it’s been the cause of problems for users elsewhere on the forum. Try uninstalling it & download it again, also close everything in the background to make sure it’s not a memory issue on the phone.
I use Tweak all the time (and on a lowly 3GS) & never have any such issues, so I don’t think it’s the software.
iDR32 mixrack
MixRack for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless)
Sennheiser IEM (for PFL)
Dante card (soon!)
It crashes. IP’s are all set right. Gota try to re-instal.
ThanX
Pitk.
iLiveT80 / iDr32
Same problem here. Tweak crashes quite often. I use MixPad on the same wifi network and it rarely crashes.
John
System Integrator
Entertainment Arts Inc.
I can’t even remember when the last time tweak crashed but, as a rule when apps start crashing on my phone I power it down and restart it and that clears it up. Are other apps crashing on your phone? Maybe you need to do a restore of the phone?
112T/IDR48/IDR16
quote:
112T/IDR48/IDR16
Other apps run fine. Tried to re-instal, made no difference.
iLiveT80 / iDr32
Then its probably time to contact technical support. Maybe they can help sort it out.
112T/IDR48/IDR16
