A friend of mine tried to use an iPhone and iLiveTweak software to Connect to my idr64. He wanted to do his own mix on his inEar system which I plugged on a dedicated stereo aux.
When he connectet everything worked fine, but he couldnt swich to his aux mix? He was only able to change the main FOH mix but nothing else.
Can anyone please explain how I can change to his dedicated aux mix, please?
Iâm not sure if I told it right. I think this is a misunderstanding ;(
In the ânormalâ editor program I can go to the mix channels (eg. my aux mix) press the mix button (under the fader) and all the input channels change color, so that every change I do on the input channel faders only change the volumes of the aux channel I formaly pressed.
So I dont want to change the volume of the aux (OUT) but the input channels independently. Itâs no problem with the laptop editor program to do your own independent mix on just your aux, by changing volumens in the input channels, when the mix button of your aux channel is pressed.
Whats missing in the iLiveTweak is the mix button at the aux (OUT) channel, or am I getting something totally wrong here?
There is an iApp in the pipeline ⌠âOneMixâ Personal Monitor app due to be sent to Apple for approval on the 19th Nov. It will then take a few days for Apple to release it at an expected $7.99 to purchase. Whoo Hooo!!!
Cheers
Richard Howey
Audio Dynamite Ltd
