I'm having problems trying to record to SQ drive. Have a 64gig flash drive.
Trying to record onto a 64gig flash drive. Tried both 16 track and stereo but shows a bunch of errors. I did format the drive which I did use for 1.5 update.
What is the drive rated speed?
It takes a faster USB stick to maintain multitrack recording but even slower drives
work for stereo.
What USB recording format are you using?
Just to ask have you tried a fresh re format?
Have you tried recording to another USB stick? Even if it’s a small one you can just record enough to see if you are getting errors or if it is working. I suspect the USB stick you are trying to use is the issue. Are you sure it is completely clean and doesn’t have any small hidden partitions with auto-run crap installed by the manufacture?
