Quick question - Is it possible to import a Custom control config file that was created for an AHM32 and use the relevant bits of it in an AHM16 Custom Control config?
The reason I ask is that I had to install an AHM32 recently because there was a shortage of AHM16s. I now have an AHM16 and want to swap out the AHM32, because the customer didn’t pay for, and doesn’t need the AHM32 !! Thanks.
It does, but if you’re using V1.3 or newer, you have to swap out the unit in the CC config for a 16, then highlight all the widgets that were specific to the 32 and make sure the new unit (the 16) is selected.
A slight bit of pain, but is necessary given the new multi-unit controls
