improvement of Mixapp for iPad
first of all: yes, I like the app and use it especially for the fine work on stage
in the Mixapp you can see the input level in the preamp-window.
that’s a good thing for now.
what I noticed:
if you have defined two channels as a stereochannel, you don’t see two meters, but only one.
it would be good if you could adjust this, because it is not unimportant to check on stage whether both channels are equally well received.
thank you!
Typing values. It’s not always easy and precise to adjust levels, sends, gain, threshold…etc by moving one finger on a tablet. It would be so convenient to be able to type values through a little pop-up, by double “clicking” on the button for instance.
+1 to being able to type values! Keyboard popup would do it!
yes, I had asked for the direct input of values years ago.
if I know that a microphone needs 20dB gain, then it’s much faster with a direct input.
Global tap tempo, we have room on the right.
