Why is the SQ7 limited to 48 input channels to mix with? It seems more than capable of handling more. It has 32 Xlr inputs on the desk and with the Dante stage boxes can easily access double this, however only 48 can be used.
Its not limited - the entire SQ series from A&H was developed for exactly 48 channels and can therefore not handle more.
Iâm grateful to A&H for having so many channels in such a small âentry-levelâ desk.
If you need more, you also have to invest more.
Maybe an Avantis could be a solution for your 64 channels.
Gotta say, if I were running a show that had more than 48 inputs, I would not be looking at an A&H SQ in any case. Itâs just not that mixer.
48 channels? Thatâs a boatload of channels.
D.
Because it is impossible to build a system that is perfect for every situation, especially at this price point. In other words, A&H can only offer so many features at each price point which is why they have designed and sell different systems with different feature sets. Itâs up to the purchaser to plan out their current and potential future mixing needs and ensure they purchase a system that will meet their needs. If you need to mix more than 48 channels, then an Avantis (64 mixable inputs) or the DLive (128 mixable inputs) would be a more appropriate solution.
I mean I understand wanting âchampagne tastesâ on a âbeer budgetâ, but you can only push this so far. Eventually you are simply going to have to step up and purchase a more expensive system if you need the features of a bigger system.
Pro tip⌠You can mix an additional stereo inputs by assigning physical inputs to the group mix inputs. I used up all 48 mono last year for a band and then needed DJ stereo input, my own playback and an MC mic. I was mixing 53 channels of audio! Pretty slick desks. Iâm always finding little work arounds with them.
Before I had all 3 DX168s, I got 17 mic pres out of my SQ5 on stage by routing talk back preamp to a processing channel. Plenty of other desk donât allow this.
For us 48 channels are enough (for the forseeable future
But this topic lead us to peeking over the fence at the Behringer Wing, which also has âonlyâ 48 channels but each of them could be stereo.
In general the SQ is the better console for us, but not having stereo signals consuming TWO channels would be a very strong upgrade - and maybe not messing up the product strategyâŚ
P.S.: AND the âstereo needs just one channelâ approach would be consistent with the AUX/Groups - which also can be stereo without eating up more channels. ![]()
For a stereo input you need about twice the processing power as for a mono one.
Thatâs why you canât just say, Iâll just turn 48 channels into 96.
the âstereo needs just one channelâ approach would be consistent with the AUX/Groups â which also can be stereo without eating up more channels.
The console was also developed for these 24 AUX/Groups.
It is a feature that these can be switched to 12 mono if required - not the other way around.
Iâm not sure about that because a lot of attributes are simply copied (processing, routing, âŚ). I donât say, it doesnât have any footprint but i doubt it to be the same size as supporting 96 channels.
My point was: This is not a completely new concept to the console and A&H obviously knows how to implement it.
@processing power: Line6 (e.g.) demonstrates on the Helix, how to expand a LOT of functionality, range, features, ⌠on an even older (and probably cheaper) hardware platform - just by clever programming and redesign.
Itâs no witchcraft but a question of willingness and effort.
Sure - there is no entitlement for customers to this kind of enhancement. But good product management always helps also the supplier.
Of course, we donât know the details of the SQâs structures and reserves.
For example, the question is: Is the same 2-channel compressor used (wasted) in each mono channel as in a stereo channel?
Or can SQ only compress its current maximum of 24 stereo channels?
Only A&H know something like that - but they wonât tell us. )
The creative ways to squeeze a few extra channels has already been mentioned.
If you find yourself always doing that then maybe look at the next level of mixer.
That said if you find yourself sometimes coming up a few channels short look at the inputs your using and get creativeâŚdo you need two mics on the snare and or kick drum, do you need a mic on the bass gtr cabinet and a direct line, if the drummer has a lot toms maybe Y the first two mic together. With the above NO ONE in the audience would notice!!
