Individual Channel Mute Group Override
It would be really nice to be able to override a mute group with an individual channel mute. When I have a group of band instruments muted, but want to bring the piano back for a bit by itself, I need to channel mute the entire band group, unmute the mute group, and then unmute the individual channels (in my example, piano) that I need. On other consoles I have used, I can press the channel mute button while a mute group is on to override the mute group. Of course, this would need to be an optional setting but would make my workflow much easier.
Plus one for this! I do not need it often, and sometimes I know in advance that an instrument will be playing solo, so can remove it from instrument mute group, but have been caught just like you when sudden change in running order or other special happens.
Plus 2 for this!!!
3rd for this. The current function makes it extremely limiting live to be able to adjust to the musicians on stage if 1 wants to play by them selves without having a nearly infinite # of mute groups to anticipate every scenario (making the simplicity of mute groups not simple…)
FYI - this request has been implemented in the 2.0 firmware release for Avantis.
How does this work? As I have vocals on a DCA. And I mute the DCA, but I can’t override the mute of a vocal channel.
Press and hold the reset button, then press the mute on the channel you want open.
To put it back into the DCA mute, just mute as normal, though once will hard mute, twice will set it to open but muted by DCA.
