Input channel PAFL seems to be post fade
Not sure why, by my sq6 seems to be doing input channel pafl as post fade only and I can’t seem to fix it.
Is there a setting I am missing?
In a show at the moment.
@Mr.Si
You can choose input and output/mix channels to be either PFL or AFL using the settings in the bottom left of the ‘Setup > Audio > PAFL’ screen.
(default for Inputs is AFL OFF).
You can also select the Input to PAFL source just to the right of this.
Ohhhh!
I think I see what’s happened.
It’s set to on for both inputs and outputs.
Thank you Keith.
Simon
P.s. I got by in the end without the need for it.
