Input Direct Out Pre or Post Trim?
Hello,
Does anyone know if I can set the Direct Outs for Inputs to be post Preamp but pre-trim on a GLD112? The block diagrams make me think that this is not possible. The scenario is a case where I want to to feed the monitor output via input direct out, but give my FOH guys the trim control on the surface so that if they need to adjust the input stage for the house they don’t hose up the IEM mixes.
Any help or alternate ideas would be appreciated.
John
The bigger question is will you have enough outputs to do all the mics you need? There are only a total of 24 if you have all the stage boxes plus the desk. But you need some of those for mains, auxes, Etc. Not like an analog desk where most have a DO for every channel separate from normal outputs. If you only need a few the you should be ok. As for your primary question I am not positive but think it is farther downstream. Will try to verify. Maybe someone has immediate knowledge.
I believe we are talking about slightly different things. When I say monitor output I mean the digital monitor output on the AR that feeds either AVIOM or ME-1. I have assigned the appropriate inputs to the digital monitor sends (on the I/O page) but have already had a few occurrences where an unforeseen change on the channel pre’s changed the band’s Ear mix. Id love to set the direct out sends to the monitor output “pre trim” so that the FOH guy can just use trim in case something needs to change.
John
Sorry. Misunderstood what you are doing. Don’t have a console setup right now to test. On demo to customer.
George
Mid-America Communications A/V
Hello John,
Direct Outs cannot be set pre digital Trim, but you can patch ‘Input Sockets’ to the Monitor outputs - this is the signal straight after the preamp. One drawback is you won’t get your GLD channel names to ME-1 as sockets are simply called ‘dSNAKE 1’ or ‘Exp 1’ etc.
Hope this helps,
Nicola
Thanx Nicola,
In the end what we have ended up doing is ordering a whole ME-1 system and get rid of the AVIOM rig. With the built in limiters, etc., I think the ME-1 system will help to alleviate the issue of pounding dynamics.
John
