I wish an input matrix to send an input into many channels.
Each channel can have only 1 input (or none).
Basically, a way to duplicate input into many channels for different processing.
For example In1 into ch1 & Ch2 & ch3, ch1 to main vocal, ch2 to monitor with different compression eq and sends, ch3 to in ears. In2 & In3 will be locked/muted, unless unused channel is selected in the matrix.
Hi Steffen, what’s unclear?
We can’t have any more channels or groups since processing resource are limited. A way to address is “share” input between channels. The most friendly way is a matrix. Since CQ can’t sum input, the matrix has to have only one input each row.
Yes I know. This is a feature request.
It is useful to patch cable into different input; say one cable of the snake fail, in input 2. On stage they swap input with 7. You can from laptop change input 7 (if connected previously) to ch 2, the show goes on.
Less devices you got on stage, less failure likely happens. Also portability and fast stage setup may be important. More friendly and comprehensive system are better!
i agree with you, it would be great to have a multiple input matrix! better you can also route analog and sd-input the same time realizing a virtuell soundcheck.
Looks like it’s been a couple of years. I just switched from the XR18 to the CQ thinking it would be an upgrade. But this feature is missing! If the XR18 why can’t this thing do it? I need the two channels, one to EQ the occlusion out of my in-ear mix and the second to send to front of house. Unless someone knows a workaround, besides a Y splitter. Thanks!
