It would nice to be able to insert a blank channel so that the others that follow afterwards are knocked on accordingly.
Example: I have a band setup with drums on first seven channels, then 3 x guitars and 3 x vox, so 13 channels in all. But then they spring a surprise and add another guitarist. Now I know I could stick it on channel 14, but I’d rather place it with the guitars to keep a nice structure to my setup. So in this case, add the extra channel at 11, but so that the vox channels are then all shunted forward by 1 channel.
This would also be helpful when replicating scenes for other bands that may have slightly different requirements. I currently use a cut & paste method to transfer affected channels one channel to the right.
+1 for this but would have to think about how the end channels bump. Perhaps everything shifts right and 24 is deleted, whatever it is! Or a “move channels” dialogue instead where you specify the first and last channel to be affected (e.g. 13 to 18) and then where you want the new slot to be (e.g. 14 to 19).
Work around is re assignment on the stage box if you have one. Or obvious would be add the channel at 14 but create a custom layer. Set that layer up however you wish. Not the same thing but close. Or get a GLD. You can rearrange anyway you wish.
I’m sure Giga understands the custom layers and that would probably be my solution if this is a one off. However, if it’s a regular thing, it’d be nice to get them in the correct order. The problem with an insert is that something has to disappear, and you may not want it to be the last channel…
Cut & Paste is a pretty quick thing to do though if it’s only three channels, but I can see it getting tedious if you wanted to move a couple of dozen channels!
Alternatively, save each singer’s channel in the user library, and recall them in their new positions. Takes a little longer but you have them there for future reference.
Haha, yes he does ! I missed the fact GCumbee already mentioned the custom layers.
Thank you to Heirloom anyway !
Back on topic: if the TS would just insert 1 or more empty channels at the apropriate spots he can turn them into whatever channel using the libraries at any given time and don’t have to worry about the “bumping up”.
Also, Custom Layers I use frequently on my QU16, but I like to have my FX sends on there as well so replicating the inputs in a different order would lead me to run out of channels pretty quick.I knew I should have gone for a QU24 but finances simply couldn’t stretch at the time (or now for that matter!).
