Insert points directly from Dante i/o
Hi. I would like to use an external Dante interfaced DSP unit as an insert point effect. Is it possible to directly assign Dante inputs/outputs to Sends/Returns of insert points of input channels or mix buses? So far I haven’t figured out a way to do it. Or at least a workaround. Thanks!
Go to the channel, select the “insert” page, and choose IO port as your source/dest.
Thanks, I got confused for some reason when it was so easy. Just tested and works fine.
