@KeithJ A&H
I really hope that you are using all digital inside between the ADC and the final DAC.
And I know you allow 18dB headroom. That is the value I always set for my digital work with DAWs.
So, Congratulations! That is the correct value in spite of all the folks who think they can get by with much less.
Or archaic analog folks who are afraid of ‘noise’ by using a large headroom but do not fear clipping.
Relating dBFS to SPL is quite easy.
We set a steady signal of 0dBFS on the LR and then move the power amp until we measure the 85dB SPL in the room.
Then when the green leds show 0 we know we are at our maximum.
And when they bounce between -20 and -10 we know we are in the good range for optimum intelligibility of speech.
I apologise if you think I have been rude. I never intended to be rude to you. You have always been polite and helpful.
What I do see, from my perspective, is that a couple of others have been way beyond rude in their replies to me.
I will admit that when attacked by bullies I will stand up for myself and might reply in kind to them.
We are having your dealer come in once more to tweak things.
They have made significant progress, but our MD and A1 only seem to address one issue at a time.
I was hoping to make this the last time we paid people to fix things that should never have been wrong.
To be fair we all inherited the set up and the MD was not a digital person, and not really an acoustic one either although he has excellent ears for music and how it sounds, when the dealer first replaced our old large analogue AH mixer with the somewhat smaller digital one, so he (MD) did not insist on everything being set. To be fair with the acoustic issues with a reverby echo, which the dealer has now fixed with special panels, we could not have done much useful back then, but now we need to do it all right and make it final.
We could live without seeing the SPL on the Qu leds. We often measure it by hand now, but that is just a one time value when we really need a LUFS readout on the Qu. LUFS meter on the mix would be a plus so we can feed a proper signal to the video team doing the livestream with our sound mix.
I appreciate your assistance.
I would hope you could grok both high end and other concepts that are lower at the same time.
I am not questioning audio engineering fundamentals just your choice to ignore a basic one that I always had available in the past, admittedly now a somewhat far past to adjust the channel strip to the output with another amplifier.
It really seems y’all find it too easy to add gain by shifting bits that you over look the need for enough gain.
I wonder if it is because most users do not use one channel with someone talking and most of the time it is 8++ channels with music that would add up to a humongous signal.
I will have to look at DCAs again and better understand them. I do know digital (far better than most folks as I had that in grad school in the 60s) and DAWs but the AH mixer is far different than the analog ones so there are many new concepts , almost too many to do until needed, to learn. I admit that since they dont seem to exist except as a concept that I did not make them a priority.
