Intermittent noise on outputs (L worse than R) — Qu-16, persists after hard reset
Hi all,
I’m having an intermittent noise issue on my Qu-16. The noise only appears on the outputs (not tied to any specific input) and comes and goes sporadically — it’s not constant. It’s noticeably louder on the L output than on R.
Troubleshooting done so far:
  • Updated firmware from V1.95 to the latest V1.99
  • Performed a full hard reset (Reset + Setup keys on power up)
  • The noise still occurs after both of these steps
This suggests it’s not a settings/firmware issue at this point. Has anyone experienced something similar that turned out to be a hardware fault (PSU or DSP)?
Thanks in advance.
To potentially narrow down the error:
What happens if you swap the connectors at the two outputs?
If now the connected right-hand speaker has louder hiss, it is very likely a hardware defect in the console.
However, if your connected left-hand speaker still has louder hiss, the problem is not originating from the console, but rather further along the signal chain.
After doing what SQuser suggested I’d start with unassigning EVERYTHING going to LR and from there on one by one re-assign everything and see what happens.
Good luck !
Giga
Does the noise appear on the headphone output or the ALT out?
If it not under warranty and you know someone who is good at taking things apart and getting them back together as well as being familiar with working on electronics you could open up the mixer and go through and reseat the ribbon cabling. Yes lots of small screws to take out, I’ve opened up a used Qu16 I bought because there was a loose screw inside and to give a clean up.
