Would be nice to be able to internally route - for example BT Left to one track, right to another track to be able to play backing tracks and click. Or input 1 to input 2 to get a different processing for the same audio source (example a singer IEM needs to be EQ’d very differently )
Yeah, the same input to multiple channels would be very nice have
+1 for this feature request
+1
+1
+1
+1
This would be super convenient for us!
I’d like to set an anti-occlusion EQ for their own voice only on the IEM of each of our singers, but have everyone else hear the normal EQ. Currently, I physically split the mic signal and use two channels. It would be handy to be able to route the ADC out of one channel to the input of another channel and thus use only one jack without Y-cable.
+1.
I think it will be possible to make a “dynamic eq-ish” by sending the input to another channel, pass the low and compress/limiting, and cut some lows from original channel. Should work…
+1
+1
+1
input output routing matrix would be great
1+
I’m sorry if I’m not understanding what you’re asking for, but let me state what I think it is - you want signal from a single source sent to multiple inputs so that they can be processed individually. If that is correct…
…for a Bluetooth source, route the audio to a set of outputs, run cables from the outputs to an input, mute Bluetooth to Main L/R Out, and process the inputs normally.
…for an analog source, send the output to multiple outputs and applying the processing on the outputs.
…for effects, apply different effects as needed and control which effects are sent to which outputs on the FX output settings screen.
…for EQ settings, outputs have their own EQ settings.
Please let me know if I am missing something, I am always ready to learn.
+1
Hi
« you want signal from a single source sent to multiple inputs so that they can be processed individually. If that is correct… »
From my perspective yes, it would be great to be able to route one input signal to multiple inputs so they can be processed individually if needed ![]()
this has already been requested multiple times
+1000
- have the possibility to split to mono also the digital/stereo input (usb, st1, st2, bluetooth)
- input, output and usb in,out routing matrix, with the possibility for example to assign one out bus to multiple output (aux1 and aux2 for example) and one input to multiple channels (input8 to channel 8 and 9 for example, useful for vocals or separate mixes on different aux)
also behringer xr18 has this and soundcraft ui as well (i think also mackie) so i don’t understand why they don’t add it
+1 for softpatch features
+1
+1.
Cloning inputs would be very useful.
+1 indeed, adding a set of virtual inputs, to which a physical input could be duplicated. This would allow managing separatly the send to the FOH, and the send to monitors, with distinct processing and effects. At least 8 virtual channels would be very appreciate.
