How i can send channels IP 41-48 to ME-1 (GLD80)?
In setup->I/O->monitor i see only 1-40 IP. Then i see on ME-1 (key for source) only the same 1-40 IP.
Jan
Jan
Hi Jan
The ME-1 is a 40-channel mixer; there’s no way to give it more than 40 channels (apart from using the stereo Aux Input on the ME-1 itself).
Hope that helps
If you don’t need all the inputs 1-40 then you can cross-patch on the I/O screen:
Monitor tab, select any ME channel, choose input 41 in the drop down - if you want a range then choose the end channel, you will see the ‘sockets’ being highlighted. Press apply. you now have channels #41 and above in your ME system. As Jeff says you can only have 40ch at any one time in ME, but you could have different patches in scenes / shows on the GLD and also recall different setups on the ME.
Very thanks, it help me. It is very easy.
( i was searching USB IP 47/48 on Monitor first screen) ![]()
Jano
How do I perform the same onthe t112 surface?
Hi RG,
Assuming your ME-1 is connected directly to an M-ACE card in Port B of the MixRack, signals patched to Port B 21-60 will go to the ME-1, as described in the User Guide.
Using the Output screen you can patch any combination of signals to Port B 21-60, including MixRack Inputs, channel Direct Outs, and mixes.
Hope this helps.
I will try this - as service is on Sunday…thanks. Any directions on controlling the IEM source volume into the ME-1?
