Trying to connect to the CQ4u app on iphone keeps asking for ip address.
Where is this located? I tried network but nothing about ip address.
Open the app on phone gives the option to choose unit but nothing happen when I
Try to choose it. Just gives me demo and other that’s all.
I had this problem. My solution was this:
Remove the CQ-4You app then cycle power on your phone then reinstall app.
You need to make sure the phone is on the same network as the mixer
For some reason, A&H devices don’t ever seem to have a place where the system will display what it’s IP address is if it was set to DHCP. To make matters worse, most of their devices (I don’t have a CQ to check myself) don’t have the MAC address printed on the device or displayed anywhere in the software, so it’s literally like trying to find a needle in a haystack when you need to determine what the device’s DHCP assigned IP address is.
A&H says that it is “best practice” to use static IP addresses with their devices and while I don’t disagree with them, I do think it is pretty shoddy programming to completely fail to include a way to show the device’s MAC address or DHCP assigned IP address.
As long as you have a device logged into CQ mix pad, its IP address can be found in:-
Home/system/info, line 11. And the MAC address 2 lines above.
Also on config tab/Control and Network. Current IP also displayed in lower panel
On the SQ the DHCP address can be found in the network set up menu.
On the Qu in the utility menu under the diagnostics tab has the info.
