IP8 Fader calibration?
is there a way to calibrate the IP8 faders?
in my case the values of the zero line deviate by 5dB
Hi Wolfgang
The same with my IP8. Seems more like a misalignment of the markings or a bug. Because every fader has the same offset.
bye
Rainer
Seems like a dead thread, but any update on this? Just got our IP8 and I notice the exact same, “feature.” markings seem to be off just a bit for 0…
The problem is over for me.
this phenomenon occurred after a new firmware appeared. after i connected the IP8 a few times, the error did not occur anymore.
this is still an issue for me on the latest firmware.
Not on my side…
What firmware Version is the IP8 showing?
If you use the “Audio Taper” Option, the 0dB mark lines up. Version 1.71
