I have the Aux PAFL and Mix buttons set to follow.
Symptom 1.
If I connect the IP8 and PAFL the Aux from the IP8 side, the Mix button is not enabled.
Symptom 2.
When IP8 is connected and Aux PAFL (Mix Follows Mix PAFL) is enabled on the Avantis side, if Aux PAFL is deactivated from the IP8 side, the Mix button is not deactivated and the Mix button remains enabled.
In other words, IP8 does not follow the Avantis settings.
Is there a solution to this problem?
IP8 v1.32
Avantis v1.30
