IP8 on Mixrack tab bug
Hey guys, have a CDM32 here running the latest firmware, controlled with a laptop running Director and also an IP8.
All has been running fine, however since I updated it to the latest firmware, when I try and add the IP8 in to the Mixrack tab, it see’s it in the popup, however it won’t connect unless I type the IP address manually into the Name/IP field. When I connect it to the surface tab, it connects just fine. I have tried a different IP8, and several different show files, same thing happens. Any ideas? Is it just a bug?
Cheers
Waz
