When i scroll from left to right or the other way it takes the faders a second to catch up and get into place. Is this just how it is when working on an iPad? Are there any tweaks to shorten the delay? If not is this being addressed in the firmware update?
delay on the ipad or on the console?
Do you have multicast on?
I don’t use a console. It’s on the iPad…not sure if I have multicast on. What does that allow?
How does one go about turning multicast on for the IDR if not using a console?
This is on my IPAD as well.
So i think its normal.
You may just b getting the delay from the iPad scrolling action. If that’s what you’re referring to there’s a couple ways you can speed it up a bit. Either drag the faders and stop with your finger before you lift it or flick the faders, then tap a moment to stop the motion. They still will take a bit to settle to a slot but it does speed things up.
You may notice that when you first access faders that you haven’t scrolled too before they seem to update, but after that they have the current settings as well.
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad2
